Spark plugs,
Old Aug 5, 2011 | 04:12 PM
kput's Avatar
kput
Default Spark plugs,
I was just randomly thinking about upgrading the spark plugs in my car,
the ones in them I assume are new from the dealership, but I just want an upgrade.
I'm not looking to spend $70 on them,
so here are my 2 choices,
should I go with either of them?
Pros, cons? Just stick with what the dealer put in?
http://www.americanmuscle.com/ford-s...0710gt500.html
http://www.americanmuscle.com/ngk-pl...kplugs-v6.html
Old Aug 5, 2011 | 04:30 PM
usc49erfan's Avatar
usc49erfan
well you can't use the first link, unless you have the 500, but also those are the same POS spark plugs in there, thus the OEM or Original Equipment Manufacturer. don't know if the 6 models have the same stupid 2 piece plugs, but make sure when you do buy some buy ones that are 1 piece and when you take the original ones out be VERY CAREFUL if they are the 2 piece. I think there is a how to someone on here about the 2 piece plugs
Old Aug 5, 2011 | 04:50 PM
MadStang40's Avatar
MadStang40
I replaced my original spark plugs with NGK iridiums. Originals were 1 piece and the NGks were also 1 piece. Relatively easy removal except for cylinder 3. Make sure you gap them correctly. I forget what the gap size is supposed to be, but you can find it in your owner's manual.
Old Aug 5, 2011 | 05:19 PM
simplexdesign's Avatar
simplexdesign
Champion one piece
http://www.summitracing.com/parts/CPN-7989/
Old Aug 5, 2011 | 05:28 PM
JimC's Avatar
Super Moderator
There isn't any need to spend a lot of money on plugs for the 4.0. The cheap plugs do fine, most go with the autolite 5143, even those with forced induction. I run the NGK TR6 plugs with my Xcharger, they cost me less than $2 a plug.
And we don't have the same plug problems that the GT has with the two piece plug. And simplexdesign is right that one plug is a PIA - none of them are particularly easy since you really are working blind for the most part and it is done by a lot of feel.
Gap them and put some anti-seize on the threads to make it easier next time.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
