Shaker 1000?
I mean, I bought the car for 15 grand. 49k, no scratches, red interior, no problems. I couldn't find anything around OKC under 17,000 that I felt was worth it. This guy was going to graduate school in Amsterdam so he said he was trying to get rid of it. I really don't think it would of made a difference in price if it was the 500 or 1000, i think he would of stayed at 15,000.
For a stock system, yes, it's above par, and the 1000 IS as good as it gets for the mustangs, stock. And yes, the subs in the trunk are 2 '10s, with factory wiring and amps, that is the only difference between the 1000 and 500. Base system would not have the door 8' subs/cut-outs/amps in addition to missing the previously mentioned trunk set-up.
Good deal. Just arguing the point that the shaker is great. For a new ordered one, far better to just skip the 1000. In most cases for a used, I couldn't see this really affecting the price much if at all. If they did ask more citing this specifically I'd likely be in the news, as I'd probably get hit with a tire-iron due to laughing in the guy's face.
RMS wattage for the amps (and each speaker uses it's own) is under 60 watts for the front 8' subs, I'd wager they're not using different IC's to do the 10's in the back either. As the speakers are matched, it makes good use of it, but you'll only give yourself minor hearing loss, most of the rattling will just be due to loose plastic pieces in your own car, and the guy blastin' it next to you at the stop light with the after-market setup won't even know you're playin' anything.
Attempting to power any of those with an after-market amp at that RMS range or above generally turns them into confetti. But for what it's using and being stock, anything over having to speak loudly with it cranked with a half-way decent bass hit and voice replication is an accomplishment. With this you will need to yell inside the car once you replace the head-unit itself if you crank it. Seems to be enough for the average person. I still can't wait to chuck it myself once I have the funds, but that's me..
JoshyGT
Sep 19, 2017 08:52 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
