HELP! Problem Removing headlight bulb
Old Sep 16, 2011 | 04:19 PM
JayBeStangs94's Avatar
JayBeStangs94
Arrow HELP! Problem Removing headlight bulb
I bought silvania silverstar bulbs for my car. I replaced the right headlight bulb. When it comes to the left one, the electrical connector will NOT disconnect from the bulb. The owners manual says:
Disconnect the electrical connector from the bulb by depressing the retainer clip and pulling rearward.
I do exactly this, and ive pulled with all my strength. Does anyone have any suggestions? May have to consider pulling out the lube!
Old Sep 16, 2011 | 04:26 PM
2005Redfire6's Avatar
2005Redfire6
I've had a similar issue, try using a small screwdriver in order to make the clip pop all the way. Or push the connector together and try again, sometimes it gets caught.
Old Sep 16, 2011 | 04:31 PM
JayBeStangs94
Thanks, Redfire, Ill give it a try.
Old Sep 16, 2011 | 04:54 PM
IndecisiveS197's Avatar
IndecisiveS197
I just changed mine too. I found it easier to remove the bulb out of the housing and hold the bulb in one hand (not by the glass obviously) and the connector in the other. Push the thing down, push the connector and the bulb together and then pull them apart.
Old Sep 16, 2011 | 07:44 PM
Nuke's Avatar
Nuke
They can be stubborn. Assuming you've properly unsecured the clip, it may take some wiggling while you pull.
Old Sep 19, 2011 | 12:14 PM
JayBeStangs94
The screwdriver tip worked. Just got a small screwdriver to push the tab, pulled out after a few yanks. Thanks.
Granatelli Sales
Jan 20, 2020 12:34 AM
spamedic
Sep 9, 2015 12:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
