DiMora's Battery Relocation Thread
Old Oct 17, 2011 | 07:55 PM
DiMora's Avatar
DiMora
Default DiMora's Battery Relocation Thread
I decided to move my battery to the trunk.
There are a few reasons why:
1) This car is nose heavy and lacks rear weight, and therefore rear-end traction. Anything you can do to move the weight bias rearward will help handling and drag-strip launching.
2) The last time I had the battery out, I was surprised how heavy it is. I looked it up: It is 43.5 pounds, to be exact (Optima Yellow Top).
Number one coupled with number two looks like a win to me...but I also have more ideas for this mod:
3) I have my eye on a big aluminum intercooler fluid tank. The more fluid you can add to your system, the better it cools - however, one must remember that water weighs 8 pounds a gallon, so it is a partial trade-off.
Something like this Canton model number 80-235; about $170 or so, looks pretty sweet to me:
Anyway, onto the battery relocation project...
First, I procured the relocation kit from Jegs. It is made by Taylor. You can get cables in a couple different choices; I chose two gauge welding cable. Welding cable is a bit more flexible, and also has a double shield - an outer red rubber type shield, then a tougher white inner shield.
For a junction, I went with a StreetWires four-way junction block and a 1/0 gauge ring terminal. The four outputs can handle four gauge cable.
First, I jacked up the right front of the car and removed the right front wheel and inner fender splash-guard. All that is needed is a phillips screwdriver and a panel popper tool to remove the plastic plugs:
Before (Optima yellow-top, StreetWires terminals, and the side terminal is for my subwoofer power):
Splash guard removal:
See that big rubber grommet with wires coming through it in the above pic?
See this little nipple? This little rubber teet?
CUT THAT TEET OFF!
AAAAHHHHHHHHHHHHHHH
OK, OK...simmer down now...regroup...focus...
Back to the trunk:
I mounted my box like this. Make sure you know where your threaded rods will go and don't drill something you may regret.
I ran the black ground cable to the upper lip of the spare tire area, right by my KB Boost-A-Pump. I cleaned the metal off really well with sandpaper till it was shiny and bare to insure a perfect ground. I added a ROUSH sticker for extra panache:
You can also see in the above shot that I ran my cable forward on the driver's side to the seat, then cut straight across to the passenger side. From there, I ran it in the interior under the carpet on the passenger side and up to that big rubber grommet.
Remember the teet I cut off?
Here is why:
Split-loom that little bizzle for protection:
Add junction block....and...Voila! Success!:
The two gauge feeds:
1) Alternator
2) Underhood fuse box
3) Subwoofer amps (fused 4 gauge 0 you can see the clear fuse holder)
4) Starter
Note my ground cable: 4 gauge ring terminal mounted to strut tower...I used the OEM ground location:
I'll be adding a "PUSH OFF" switch for drag racing later on, and I already have the trunk liner / carpet re-installed, but it was dark when I finished so I didn't take pictures yet, but will do so soon.
I put it on the driver's side since I have a sub box on the passenger side.
Old Oct 17, 2011 | 08:04 PM
bakerjd's Avatar
bakerjd
Very nice write up...hopefully this will get a sticky because it's very informative!
Old Oct 18, 2011 | 02:56 AM
2005Redfire6's Avatar
2005Redfire6
+1, good write up man. I did the same thing when I put my Vortech on except mine is on the other side of the trunk!
Old Oct 18, 2011 | 07:24 AM
DiMora's Avatar
DiMora
Indeed..If I did not have a sub-woofer box, mine would also be on the right rear passenger side.
Old Oct 18, 2011 | 07:47 AM
07mark's Avatar
07mark
Off topic, but
What style strut tower brace is this?
Old Oct 23, 2011 | 02:02 PM
DiMora's Avatar
DiMora
Originally Posted by 07mark
Off topic, but
Steeda Billet; actual brace will no longer fit due to TVS blower / hood clearance issues.
Back on topic...Sorry it took so long to add final shots...been very busy.
Final outcome for now until I add a cutoff switch:
[/QUOTE]
Old Oct 23, 2011 | 02:19 PM
2005Redfire6
Very clean like said before, looks great!
Old Oct 25, 2011 | 09:12 AM
DiMora's Avatar
DiMora
I ordered a Stinger 200 AMP breaker to protect the car in case I crash and am incapacitated:
Old Oct 30, 2011 | 06:31 PM
DiMora's Avatar
DiMora
Alright, 200 amp Stinger car audio-grade circuit breaker added.
I re-located the positive cable to the back of the box to make the wire routing a little better.
I used a hole-saw I had lying around that was a perfect diameter to match what the boxes stock holes were, and I de-burred with a file. I'll add some split-loom for extra measure tomorrow morning before I call the job done.
Positive battery terminal is now a Stinger as well. It has a plastic insulating cover on it that is hard to see. I have a negative terminal that matches, but I need some more 1/0 gauge ring terminals.
My buddy holding the box so I can shoot an image of the new hole:
The positive terminal has clear heat-shrink covering all exposed metal, and then I added some 3M foam body tape and left the top backing on it where it crosses the battery securing bar for extra insulation. A single zip-tie holds the breaker to the securing bar.
Finished for now until I split-loom all exposed wires and add zip ties:
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
flash_xx
Oct 16, 2015 07:23 AM
KingRando
Oct 2, 2015 08:06 AM
