Shifting issues
Old Nov 2, 2011 | 09:42 PM
2010stanger's Avatar
2010stanger
so i guess this tranny isn't made to be smooth.
Old Nov 2, 2011 | 11:27 PM
HxCGuitars's Avatar
HxCGuitars
Originally Posted by johngt10
where can I find that redline at? I live In Dallas, tx.
I don't know Dallas' zip code off hand, so here you go:
http://www.redlineoil.com/dealers.aspx
The fluid that technically goes in our trans is the D4 ATF. People also run the MTF.
Also, if there's not a dealer near you (which I kind of doubt), another fluid I had fantastic results with was GM or Penzoil Synchromesh. In fact, I think it might've been slightly better feeling than the Redline, but I can't justify dumping out $40 worth of fluid to go back. It'll be what goes in for the next change. You can usually find the synchromesh at your local Autozone, Pepboys, what have you.
Also, no, these transmissions aren't meant to be smooth, at least from my experience.
Old Nov 3, 2011 | 03:24 AM
LordRipberger's Avatar
LordRipberger
I need to change my transmission fluid on my 06 V6. I don't think I need the most expensive stuff. What would you suggest? Mine is an auto and doesn't seem to have any issues. I bought the car at 55K and now has a little over 70K. I have no idea when the last transmission fluid change occurred.
I need to change the oil too so I thought I would do it together.
I have changed oil in cars before, but are their any best practices for trans. fluid changing as this will be my first time?
Old Nov 3, 2011 | 07:25 PM
Hack Job's Avatar
Hack Job
I switched to AMSOIL Synthetic ATF a couple months ago. Shifts nice & smooth. Now if I can find someone who wants to trade their MGW for my Hurst...
Old Nov 16, 2011 | 01:15 PM
FordService's Avatar
FordService
Official Ford Rep
I've noticed that with my 2010 as well but I may just do the synthetic blend. I think its due anyways. Whats the mileage again for the fluid on the trans?? I always get different numbers from people.
Sorry, just saw this. Transmission fluid should be checked every 15k miles. For manual, it should be changed at 105k, and for automatic, at 150K. Click here to check out the 2010 Maintenance Schedule.
~Natasha
Old Nov 16, 2011 | 07:01 PM
ym42's Avatar
ym42
My shifts were rough at the beginning too, but got much smoother with time and miles driven, plus I changed the fluid to Mobil 1 that seemed to help a bit too...
Old Nov 24, 2011 | 11:26 AM
Quicker10u's Avatar
Quicker10u
I switched to a blend of 1 Bottle of Royal Purple Synchromax and 2.2 bottles of Mobil 1 ATF and it has made all the difference in the world. Best mod I have done to my 08' Bullitt.
Old Nov 24, 2011 | 06:22 PM
robs's Avatar
robs
Getting a short through shifter helps too. Mine is 100% better just from this alone...
Oct 7, 2015 07:02 PM
degner122
Sep 16, 2015 07:09 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mustangmalo
Sep 6, 2015 05:22 PM
