where is a wire that is hot when ignition is on and off when ignition is off????
i bought a new gaslock digital stickshift that needs to be spliced into a wire like this and i have tested a million a can not find one. looking for the radio wire because i know that is the type i need to splice into. if you have spliced into a wire like this can you give me color or location of the wire, thank you
B. Using a fuse-tap(mini-blade in this case) is far preferable IMO to hacking existing wiring.
C. You will only get ACC(Accessory). and START(only on while cranking) from the radio harness, not solely an IGN(Ignition/RUN position), which from the question posed is what he states he's after.
I believe there is one tied to IGN that doesn't have a fuse(as in unused) but I don't remember, probably easily found if you wish to skim some of the other diagrams, or just test the couple of non-fused open socket in the SJB itself later.
Pic of SJB in the passenger-side kickpanel with the plastic covers off:
That specifically is from a picture for using F20(hot in start) for defaulting the TCS to off, so ignore the highlighted one.
Just had to find one myself for an install - the +12 ignition wire is directly under the steering column (just behind steering wheel, remove plastic panel held on with three bolts). There is a harness on the drivers side of the steering column, you're looking for a white / yellow wire.
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
