Gas Milage Issues
Surprisingly, the 05-10 V6's don't get that much better fuel mileage than the 05-10 4.6L's; perhaps about 1-2 MPG better. But still, you should be seeing about 27-28 MPG at a steady cruise at 65 MPH, providing you're not driving like a retard and you're not running 4.10's.
First, understand that the on-board should only be used for info and NOT as a true indication of your actual fuel mileage. If you haven't already, confirm that the speedometer is correct by using a GPS. Once you rule out the electronics, go over the basics: fuel filter, TB, MAF, tire pressure, spark plugs, air filter etc. Exhaust restrictions (mainly clogged cats) are also mileage killers.
Yes, the car was very well maintained. It has a few repairs needed, but not much. Its awesome to drive that is for sure.
For hand-calcultaing to be accurate, you still need an accurate distance from the last fill-up to the next. If the speedometer is off, your odometer will be off, too, which is why it's imperative to verify the odometer is accurate before you go hog-wild on maintenace.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
LivingInThePast
Sep 16, 2015 12:20 PM
