Can you safely turn Slotted and Drilled rotors?
Is it ok to turn slotted and drilled rotors? Just curious because my front Bear 14 inch rotors have a small vibration in them. Just wondering if anyone has done this and if it caused any issues?
Generally (I'm talking like 90% of the time), when there is a vibration upon application of the brakes, it is caused not by a warped rotor but by an accumulation of pad material on the rotor. The solution is to stomp the hell out of the brakes from - say - 60 or so. Or 80. Whatever. That will, er, remove the excess pad material. Try that before you go and have the rotors turned.
I think you can do slotted/drilled rotors, but some places might not want to. Ask around.
jwog666
Dec 27, 2021 08:09 PM
logan409
Sep 26, 2015 07:43 PM
Sep 16, 2015 07:53 PM
