Rear end noise, problem?
Old Jan 1, 2012 | 09:13 AM
majik755's Avatar
majik755
Default Rear end noise, problem?
Hi guys,
Not sure if it's a problem or not, seems to be more obvious as it gets colder. When I back my car out of the garage in the morning I hear a clunk sound from the rear end when I stop, I then put it into drive and go on my merry way. There doesn't seem to be any other symptom other than that one clunk as I stop. I have a 2010 GT automatic, any ideas? should I be concerned?
Thanks in advance from mechanically challenged Pony owner...
Old Jan 1, 2012 | 10:44 AM
SpartaPerformance's Avatar
SpartaPerformance
Sounds like there might be a worn/missing brake pad shim. Hard to tell from your post without hearing it.
Old Jan 1, 2012 | 12:47 PM
tx_zstang's Avatar
tx_zstang
Lots of them do that when cold. Craw under the car (with it not running of course) when its cold. Rotate the driveshaft back and forth, and you'll probably get it to clunk a little.
There's some intentional slack in the rear end. As the fluid warms, it's less obvious.
Old Jan 1, 2012 | 01:29 PM
wcgman's Avatar
wcgman
Seems odd...it gets kinda cold up here in CO and I've never had this problem, but all my stangs are manual. I'd agree with TX_vstang though that's its probably normal and nothing to worry about.
msavoia23
12
Jul 7, 2018 12:08 PM
Tyoung68
Aug 25, 2015 04:31 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
