engine bay cleanup question
Old Mar 27, 2012 | 03:24 PM
05MineralGrayV6's Avatar
05MineralGrayV6
Default engine bay cleanup question
ok guys doing my first spring cleanup of the engine bay ive gone as far as taking out the battery and removing the the airbox to get to some hard to reach places but still cant get it 100% clean my question is is it alright to unplug random wires one at a time to get to the hard to reach places as long as i plug them back in as i go would there be any ill effects to the electrical if i do?
Old Mar 27, 2012 | 03:37 PM
2012Kona's Avatar
2012Kona
Assuming you don't try and start it while things are unplugged you should be fine. Otherwise it will throw codes.
Old Mar 27, 2012 | 03:47 PM
Lem-06's Avatar
Lem-06
Well assuming battery is already out of the car i would say itll be ok. Just make sure you match them back up correctly
Old Mar 27, 2012 | 04:29 PM
D'prived's Avatar
D'prived
^This... you pull the battery out, nothing else matters.
Old Mar 27, 2012 | 05:31 PM
05MineralGrayV6
Already pulled it out cleaned that area and reinstalled it I guess I can disconect it when I clean the other areas thanks for the responses
Old Mar 28, 2012 | 07:36 AM
highline's Avatar
highline
not sure if his mods warrant a tune(r) <sct, ect> but say he has a brenspeed (for conversational sake) tune...will this battery disconnect reset anything, or will his tune hold steady?
Old Mar 28, 2012 | 02:04 PM
D'prived's Avatar
D'prived
It won't affect the tune. The tune info is stored in the car's computer memory which is non-volatile memory. The info is there regardless whether power is applied or removed.
Old Mar 28, 2012 | 08:17 PM
MustangFirstCar's Avatar
MustangFirstCar
You can disconnect things, sure, just make sure you know where everything needs to go back in place. Also don't get any liquids or anything into the plugs, of course.
Old Mar 28, 2012 | 09:10 PM
05MineralGrayV6
finished cleaning up the engine bay today dunno how I did it but somehow forgot to reconnect one of the wires and started up the car sure enough through a code but then I plugged in the wire, unplugged the battery for an hour then reconnected it. I started it took a few seconds longer to start up than usual, no engine light now thank god and it seems to be fine now.
Old Mar 28, 2012 | 10:37 PM
xkape's Avatar
xkape
Mineral.. if you are close to Dayton, OH, theres a meet in May.. I would LOVE to see your car and look it over and talk to you about it if you are close.
ShaneB26154
35
Mar 4, 2021 04:05 AM
drfister
May 3, 2018 10:38 PM
rakesh544
Aug 19, 2015 06:23 AM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
