tuner help plz
Old May 12, 2012 | 01:14 PM
bojanglesowner07252's Avatar
bojanglesowner07252
Default tuner help plz
ok i posted awhile back about help with a tune. I had an o/r x pipe installed already and cai/tuner in the trunk. I finally put the cai on and uploaded the tune that was there (not knowing if the tune was compatible since the x pipe was already on). anyways after i installed the cai and uploaded the tune, it seemed to drive great. but i notice when im stopped the rpms are pretty low....is this normal? also when i got home i was coasting in 2nd gear and was slowing down and rpms went real low and the engine turned off....is this a bad tune or is that normal as well because i know shift points are changed during a tune???
thanks
Old May 12, 2012 | 02:28 PM
Nuke's Avatar
Nuke
It's possible that the new tune requires a few miles to even out some of the parameters but that's usually associated with clearing the adaptive learning (disconnecting the battery for ~20 minutes or more). Was the tune written for the O/R X? If not, it may be looking for the rear O2 sensors in which case it would throw a code.
Old May 12, 2012 | 03:11 PM
bojanglesowner07252
im really not sure if the tune was written for the midpipe cause the x pipe was still installed but the cai/tuner was in trunk when i bought it. but there has been no lights or codes come on and the car sounds amazing now and runs good except for that low idol i was referring to, and then when it had cut off.
baddog671
Jul 26, 2016 01:20 PM
04stangman
Sep 17, 2015 01:45 PM
nboost
Sep 16, 2015 05:35 AM
ernesto-619
Sep 10, 2015 01:32 AM
