Redoing My Interior!!
Should have taken the money you spent on the audio equipment and rear seat delete and done the front seat brackets instead. Bad decision to not properly secure your seats and spend that money elsewhere.
Your life and the life of any passenger isn't worth $100?
Did u read the post or just look at the pictures. Btw I also got rid of the door subs...and went from manual to auto...and got rid of my chrome climate control...and changed my exterior color. Any other things you can notice??
The seat delete isnt too bad at all! Ive debated taking my seats out and doing a full fiberglass enclosure for my Kicker stuff but I use my rear seats still so its a no go for me.
But as others said, fix the seat properly. As someone knowledgeable in engineering, the setup you have is a bad, bad idea. for many reasons.
http://www.engineeringtoolbox.com/yo...lus-d_417.html
The yield strength of Aluminum (presumably 6061) is 95Mpa. A36 steel has a yield strength of 250Mpa. This is the force required to cause permanent elastic deformation (hence catastrophic failure). Now considering that you used half of the material you're supposed to use, the structural integrity is questionable at best. I think it's safe to say that you've reduced the strength of your seat brackets by a factor of 4 at the least.
Spend the 200 bucks, it may be the difference between a bad seatbelt bruise and broken bones in a moderate-severe accident.
There. Are you happy now? That's all I can say...
Links to previous threads:
https://mustangforums.com/forum/2005...-interior.html
https://mustangforums.com/forum/2005...hich-ones.html
