06 center console power outlet
Mine went out a while ago during a road trip college visit and I would like to get it working again. I hadn't looked it up in the chiltons yet but I have replaced the fuse and there isn't a penny in the socket. The old fuse worked when I tested it and I'm sort of at a dead end. Can one of you save me from chasing wires all over my car? I don't read any voltage across the socket so any advice on where to start would be appreciated.
http://iihs.net/fsm/?dir=40&viewfile...%20Lighter.pdf
Page 2, did you check fuse 61 AND 64 for the BEC? Likely you just looked at the wrong one.
Check for voltage across fuse, then yank the center console cover like you were about to install a stereo and verify the plug is connected, gets voltage, and isn't corroded. After that, ya, you're looking at tracing it back to the BEC to see where it got fubar'd. May simply be the ground off of it, when you tested for voltage did you try another source for ground?
I can't remember which is which myself, so it's either Light Green, or Light Blue with a white stripe on it. You'll know for sure once you pull the console cover and look.
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
