2006 Mustang
There are 2 common leak paths in these S197's. The less critical one is due to the cowl drain plugs getting clogged. You can see the one on the passenger side below and to the right of the battery. It's a little rubber boot that clogs pretty easily and allows water to get into the cabin thru the cabin air filter. The other is critical enough that there's a TSB (Technical Service Bulletin) on it. That one allows water to leak over the SJB (Smart Junction Box) located inside the passenger kick panel and will eventually corrode various connections and cause all sorts of electrical gremlins.
Welcome to the world of the S197 and to MF!
This is the TSB in question, complete with pics:
https://mustangforums.com/mustang-ts...LOOR-AREA.html
General TSBs:https://mustangforums.com/mustang-tsb/
Also listed at the top of the page under articles as the last link.
Search link: https://mustangforums.com/forum/search.php
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
