Fog lights stopped working???
only have like 6k miles on car, barely used fog lights, i tryed to turn them on the other night and they will not come on, but i do hear the relay i guess that clicks when i pull out the switch to turn them on but no lights??? any ideas!!
yep, wont work on low beam, idk, was just curious, car is almost brand new still has warranty, just a hassle scheduling it to take it in, but when i do i believe im gonna have them look at my rear end also, seen a little rear end fluid on my axle housing while i had car on the lift, not for sure if it came out of the breather vent or what!!!????
Ya check the SJB fuse? And swap the relay(if possible, it says non-serviceable, so may be integrated internally), they can "sound" like they're working. Might not even be that relay you're hearing. If you have your high-beams on, the fog lights get killed as well, so try switching to high/low beams as Azpete originally suggested first.
Fuse 21, 15 amp:
http://iihs.net/fsm/?dir=710&viewfil...og%20Lamps.pdf
Only other thing to check would be the ground used for those. G104, which is toward the front on the drivers side. If the wipers work, it's unlikely this is the cause(this uses that ground).
http://iihs.net/fsm/?dir=710&viewfil...on%20Views.pdf
Fuse 21, 15 amp:
Last edited by wayne613; Jul 31, 2012 at 10:13 PM. Reason: used 05-09 instead of 11+ as diagrams
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
