Sponsored by:
Sponsored by:
Old 10-22-2015, 04:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Cabin air filter change question
Old 09-24-2012, 11:49 PM
ResQman
ResQman's Avatar
I have a Vert so it really doesn't matter...... :-)
ResQman is offline
Old 09-25-2012, 01:49 AM
wayne613
wayne613's Avatar
..And in Canada to boot. Masochist.
Anyhow, ya OP, you "fixed" it backwards now. The arrow indicates airflow, as air is pulled into the cabin, hence being named a cabin air filter....The arrow shown on the top of the filter needs to be pointing toward the rear of the vehicle when you re-secure the filter-housing.
Seems to be basic common sense to me, but everybody misses the obvious sometimes..It's still going to "filter" backwards, but obviously not ideal.
[youtube]wrTcTbUux2o[/youtube]
wayne613 is offline
Old 09-25-2012, 12:33 PM
chub46
chub46's Avatar
In both my 08 Bullitt and my 2012 GT the cabin filter arrow is facing the front, towards the bumper. But as stated above it does not matter which way a clean filter is installed. The arrow is there so if you reinstall the same dirty filter it has to go back in facing the same direction it came out or you will blow the dust and dirt into the cabin.
chub46 is offline
Old 09-25-2012, 01:42 PM
baddog671
baddog671's Avatar
It should be called a climate control filter instead of a cabin air filter, just so it'll stop confusing Nuke. It's function is to keep debris out of your heater motor and A/C evap coils. Not blowing it in your face is just a bonus.
Get a leaf stuck in your heater's squirrel cage once and you'll know what the filter is for.
baddog671 is offline
Old 09-25-2012, 01:47 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Originally Posted by duckbubbles
The arrow on a filter usually indicates direction of airflow. In this case the air is flowing INTO the car.
Frank
+1 any filters (air/fuel/or otherwise) with arrows on them is to indicated the direction of flow so the arrows should always point in the direction of the flow regardless of how it was installed previously (as in maybe it was done incorrectly the first time).
Derf00 is offline
Old 09-25-2012, 03:58 PM
SkyWitit23
SkyWitit23's Avatar
Ok thanks guys so im gonna re-install it again then lol, could they have put it in wrong the first time?
SkyWitit23 is offline
Old 09-25-2012, 05:19 PM
duckbubbles
duckbubbles's Avatar
ABSOLUTELY! A 50/50 chance with a brain dead line worker.
Frank
duckbubbles is offline
Old 09-25-2012, 05:35 PM
Nuke
Nuke's Avatar
Originally Posted by baddog671
It should be called a climate control filter instead of a cabin air filter, just so it'll stop confusing Nuke. ...
Call it what you want and consider me unconfused.
Nuke is offline
Old 09-25-2012, 07:19 PM
6-Speed
6-Speed's Avatar
Here's how it's done on a 2007.
http://www.svtperformance.com/forums...placement.html
6-Speed is offline
Old 09-25-2012, 07:47 PM
wayne613
wayne613's Avatar
Originally Posted by chub46
In both my 08 Bullitt and my 2012 GT the cabin filter arrow is facing the front, towards the bumper..
Wat? It's facing toward you when you put it into the housing, when you put the housing back with the new filter the arrow should be facing the rear of the car. This has not changed, or is different in the models, or other cars for that matter.
Fresh air gets pulled in through the filter in that compartment, air flow arrow when secured...Faces the direction the air is going. Tain't a hard concept.
wayne613 is offline
Quick Reply: Cabin air filter change question
