Window Problems
Old Oct 8, 2012 | 02:00 PM
Statue30247's Avatar
Statue30247
Exclamation Window Problems
I have an issue that needs solving.
Both my passenger and driver side windows will not operate from the switches inside the vehicle. The windows do move the 1 inch or so when you close or open the door. I have not been able to find a fuse problem. i checked for power at the switch and did not find my 12VDC.
Is there anyone who had this same problem and knows how to fix it?
Old Oct 8, 2012 | 05:07 PM
Nuke's Avatar
Nuke
http://iihs.net/fsm/?dir=1
Hopefully the wiriing diagrams will help. I haven't looked.
Old Oct 8, 2012 | 07:39 PM
Menace's Avatar
Menace
Try holding the window switch up for a few seconds or until you hear a "click" ...
Might just need to reset them as it's a pretty common issue, might be the actual hardware showing its age too... but it's a quick no-cost check.
Old Oct 8, 2012 | 08:17 PM
Nuke's Avatar
Nuke
I thought about that at first but the fact that there's no motion, period, with either window besides the auto drop made me think it isn't a calibration issue. Hopefully I'm wrong.
Old Oct 9, 2012 | 12:11 AM
wayne613's Avatar
wayne613
Fuse.
The auto-drop when opening/closing the door gives it away. That functionality is an independent circuit, but still relies on a properly functioning motor and the B+ line fuses for the motors in the BEC being present/functional.
Either fuse 44(10amp) in the BEC, or fuse 6(5amp) in the SJB.
http://iihs.net/fsm/?dir=40&viewfile...%20Windows.pdf (page 1)
Old Oct 9, 2012 | 11:11 AM
Menace's Avatar
Menace
It's the first thing I recommend anytime anyone has a window issue, and when the window issue happened to me I had the exact same problem. The switch did nothing. As mentioned it only takes 2 seconds to prove/disprove so it wouldn't hurt.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
