Sponsored by:
Sponsored by:
car possibly burning motor oil
Old 11-09-2012, 08:19 PM
Steven Bannoura
Steven Bannoura's Avatar
Originally Posted by 2008saleen
Dont use thicker than specified oil in these 4.6ers. The oil pumps do not pump it very well. You need to stay with the 5w30 or 5w20.
I actually doubled checked on that, asked a few technicians and they all said that ford motors use lighter oil at the beginning then run better with thicker oil as they break in. I might as well give it a shot and if i notice any performance loss or any problems of any sort then i'll have to go to 5w30.
Steven Bannoura is offline
Old 11-09-2012, 08:23 PM
Steven Bannoura
Originally Posted by Nuke
I'd have gone with a 5W30 but what the heck...
The Motorcraft filter is about as good as you need providing you don't go much beyond 8k miles between oil changes like I used to (or still would if I was driving the Stang like I used to). Checking it weekly regardless if you drive it or not is my suggestion to getting good info.
I learned my lesson, will be checking it at least once a week for sure, even if i only drive it once every month
Old 11-09-2012, 08:29 PM
baddog671
baddog671's Avatar
Pick up a PCV air/oil separator and that should reclaim the majority of your oil, preventing it from entering the intake and being burned up. WOT at the strip will definitely accelerate consumption.
baddog671 is offline
Old 11-09-2012, 09:54 PM
Steven Bannoura
thx, iam gonna look into that
Old 11-11-2012, 08:04 PM
JThor
JThor's Avatar
Since you don't drive the car very much, it could be that your piston rings have gotten gunked up and are sticking. i have used Risolene before with good results. When it gets a quart down, put a quart in and see what happens. It won't hurt the car, and may help. It's about $6 at NAPA.
JThor is offline
Old 11-12-2012, 01:21 PM
Derf00
Gentleman's Relish
Derf00's Avatar
OP, how much oil are you putting in when you change the oil? If you're simply giong by the manual or not running the car before doing a final check, that's the problem. Manuals 99% of the time recommend less than is actually required and if you haven't started the car before doing your first oil check, it will give you a false high reading on the stick.
Reason is without starting the car first you're not taking into account the new filter which is not saturated yet.
Change your oil, get 6 quarts and dump 5 in to start. Run the car for a few minutes. Let it sit for 10. Then check your oil. Add what you need to get it to the line. Done.
Derf00 is offline
djbigskrilla
09-20-2022 01:04 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
yurizx6r
08-11-2015 07:50 AM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: car possibly burning motor oil
