V6 Limited slip
I absolutely hope I'm wrong. Couldn't find a definitive photo to make me truly believe either way. Hopefully it works!
EDIT: I'm 99% positive it won't just bolt up. Compare these diagrams
'94 Ranger
'06 V6 Stang
Either way, good luck bud.
'94 Ranger
'06 V6 Stang
The rear end won't fit - I believe that the Ranger uses a leaf spring on the rear end - mounting points are all different from the Mustang.
You can use the internal components if you want to tear the two rear ends apart. Just know that setting up the gears is going to be tough with used parts.
JoshyGT
09-19-2017 08:52 PM
treesloth
09-28-2015 07:03 AM
09-08-2015 11:50 AM
