Tuner
Old Feb 4, 2013 | 09:40 PM
Zacmustang's Avatar
Zacmustang
Banned
Question Tuner
What kinds of things can a tuner do for my car? I have a v6 2011 mustang if that matters.
Old Feb 4, 2013 | 09:44 PM
sharony1994's Avatar
sharony1994
It makes into a different car, Sharper throttle response depending on octane levels and the tune you pick. Much more low end torque. Best way to explain is, it awakens your mustang!
Old Feb 4, 2013 | 09:45 PM
SpartaPerformance's Avatar
SpartaPerformance
Go to SCTflash.com
Old Feb 4, 2013 | 10:01 PM
TomKat's Avatar
TomKat
check out americanmuscle.com
great place to start!
Zacmustang's Avatar
Zacmustang
Banned
Thank you so much for the info!
Old Feb 5, 2013 | 01:13 PM
kevinmalec's Avatar
kevinmalec
SCT tuner with CUSTOM tunes is a great first performance mod! Custom tune will be tailored specifically for your car. You can also add a CAI, for a little more performance gain.
Old Feb 5, 2013 | 06:21 PM
Nuke's Avatar
Nuke
CAI=Cold Air Intake
The CAI allows more air flow but on these engines, the tune in the PCM (Power Control Module) needs to be modified in order for the electronics to allow the engine to make USE of that extra air and the associated fuel adjustments. The custom tune does a lot to improve driveability, shift points (on automatics) and power addition. Thr bulk of the changes to the tune that affect performance are not something that you, the user, can access; those parameters are in the tune written by folks like AM/Bama, Brenspeed, VMP and others. However, the tuner will still allow you to make other changes such as for tires size and gears (although if you have an automatic and change gears, a tune adjustment for the shift points would be optimal but NOT necessary) as well as a few other adjustments. A CAI and custom tune combo is one of the best first mods.
Old Feb 5, 2013 | 07:10 PM
hammeron's Avatar
hammeron
^ this
baddog671
Jul 26, 2016 01:20 PM
12bigredstang
Sep 24, 2015 05:46 PM
04stangman
Sep 17, 2015 01:45 PM
nboost
Sep 16, 2015 05:35 AM
ernesto-619
Sep 10, 2015 01:32 AM
