Door panel removal????
Old Feb 6, 2013 | 10:51 AM
DJ Piner's Avatar
DJ Piner
Unhappy Door panel removal????
Does anyone know where I can get detailed instructions on removing the door panels on my 2008 GT conv???? I have a speaker or sub rattling and needs replacing. Also any recommendations on speakers/ sub that won't damage the shaker 500 system????? Thanks,
Old Feb 6, 2013 | 11:25 AM
ghunt's Avatar
ghunt
I have a PDF at home but not here....it's easy thought. Pop out the panel behind the door pull handle, and the door grab handle, there are screws behind those two. Take them out, and go around the edge of the door and get the screws there two (I believe there's about 8 total).
Pop the door panel up off the lip at the window, and push the panel with the door & window switches forward, it pops off, then you unplug the switches and set it aside.
Also if you want to take the panel completely off you'll have to remove the cable from the door pull handle.
I think that's all there is to it or am I forgetting anything??
Old Feb 6, 2013 | 11:45 AM
waykooljr's Avatar
waykooljr
Courtesy of Louie...
Door Panel Removal
Old Feb 6, 2013 | 03:28 PM
DJ Piner's Avatar
DJ Piner
Default door panel removal
Thanks Louie, already printed a copy Now I need to find out the best speaker and or sub woofer that won't damage the shaker system. It's completely stock and I don't want to mess it up. Again thanks a million!!!
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
