Replacement wheel studs
Old Feb 8, 2013 | 05:43 PM
silverstang23's Avatar
silverstang23
Default Replacement wheel studs
Does anyone know where I can find replacement wheel studs for the rear of an 08. I believe they are .614 knurl. The problem I'm having is all the arp are 3" long and I think they should be 2.31". Should I just cut the 3" down ? Running open lugs is not an option.
Thanks guys
Old Feb 8, 2013 | 05:54 PM
Rshustler1's Avatar
Rshustler1
I know I replaced my lug studs last year... Not only was it a real pita but I used 04 gt studs in my 05 v6 because the knurl fit better
Old Feb 8, 2013 | 06:24 PM
silverstang23
What knurl did you use? Was it the front or back
Old Feb 8, 2013 | 09:45 PM
IGO 202's Avatar
IGO 202
I cut a set of ARP's down for my Malibu and no problems. I just ran a lugnut on, cut the stud with a 3" cutting wheel, backed the nut off to chase the threads and was good to go.
Dan
Old Feb 9, 2013 | 06:46 AM
Rshustler1's Avatar
Rshustler1
It was the back and I cannot remember what knurl but I went to OReilly and the guy there told me to get the 04 gt studs, and 2 x 04 open lugs nuts to pull through and it worked and no one can tell by looking at it that they're different. I the 05 lug studs were too thick at the knurl to pill through I tried everything
Old Feb 9, 2013 | 04:07 PM
808muscle's Avatar
808muscle
I ordered mine via brenspeed. I sprayed some PB Blaster on the worn ones to loosen them up, tapped them out with a hammer. Used a stack a washers with a lugnut on the new stud to get it to pull through. You gotta take it easy cause I overtighened one and stripped the threads. Duh!!! LOL
Old Feb 9, 2013 | 08:35 PM
silverstang23
Do you happen to know which ones you got from brenspeed? I have the ones from lethal and thy are going to be way to long. Do you have closed lug nuts? And you did the rear?
Urambo Tauro
Dec 17, 2016 03:30 PM
kdryan
Aug 29, 2015 09:57 PM
dba Brakes
Aug 23, 2015 06:08 PM
jjwinel78
Aug 17, 2015 03:34 PM
FD725
Aug 11, 2015 03:43 AM
