Camber wear?
Old Feb 19, 2013 | 07:20 PM
silverstang23's Avatar
silverstang23
I had toe issues that caused my front tires to wear the same way. Nothing you can't fix with an alignment
Old Feb 19, 2013 | 07:38 PM
Ricardo's Avatar
Ricardo
I had same wear wear on my front tires and had never tampered with the alignment. Had it checked and they said it was within factory specs. But both tie rod ends were also bad at the same time.
Old Feb 19, 2013 | 11:33 PM
krazykevin's Avatar
krazykevin
I think I will get an alignment and see if can be fixed, if not, I will be upgrading the LCAs. Thanks for the input !
Old Feb 20, 2013 | 11:39 AM
whosniffedme's Avatar
whosniffedme
If you have any basic car knowledge, I would jack your car up, take the wheels off, and just carefully inspect your front suspension components. It could be several things, I know that my car was doing this because my tie rods were worn and it would throw my camber off all the time. Check for busted rubber boots, smushed components (anything that's not perfectly round like it should be), or anything loose. Take a screwdriver or something of the sort and give all the moving components a little nudge to see if it has any give, if so that might be your problem. Good luck!
vargas
Jun 17, 2017 12:17 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
