P2104 Code advice needed
Old Feb 22, 2013 | 04:17 PM
TheStigSC's Avatar
TheStigSC
Default P2104 Code advice needed
Hey guys,
So on my way home today, I got limp home mode and a CEL (which happened before but without the CEL). Now I knew eventually I was gonna have to fix it, but I had a question. I was just gonna go ahead and replace the whole TB because I found a Ford Racing Throttle Body that is stock on the GT500 and put it on. I have a Kenne Bell, so I'm under the impression that if I just flip it over (see link below) that it should just bolt right up. My question is, will I need an ECM calibration for that since I am going from 55mm to 60mm? Or a Kenne Bell update? Anything? Or should it just bolt up and go?
Thanks for the input in advance.
http://www.cjponyparts.com/ford-raci...-2012/p/TB100/
Also, the guy from CJ says he thinks it comes with the actuator but it seems too good to be true for $140. Anyone have any ideas on that? Thanks again guys.
Old Feb 22, 2013 | 10:58 PM
TheStigSC's Avatar
TheStigSC
Ok got a hold of Kenne Bell, they say it will need a dyno tune if I'm gonna install it so I am just gonna get replacement TPS and Throttle Motor and install on TB with new gasket, clean her up and clean the filter too. Hopefully she won't need the TB.
djbigskrilla
Sep 20, 2022 01:04 AM
bryan616fl
Jan 25, 2019 09:07 PM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
Elcameeeno
Aug 19, 2015 11:19 AM
defarmer
Aug 13, 2015 06:40 AM
