NEED TUNER HELP!
Old Mar 28, 2013 | 09:55 PM
crob1803's Avatar
crob1803
Default NEED TUNER HELP!
Hey guys im new to tuning. i actually bought a used sct x3 tuner. i made sure it was unmarried and such. well i plugged into my 05 gt and went through the whole process. it said tune was complete to unplug and it started flashing "failsafe mode" and my car wouldnt start. i tried 87, 91 and 93 with all of the same result. i flashed back to stock and it started up. any ideas on why my car wont accept the tune???
Old Mar 28, 2013 | 11:18 PM
FinallyHappy's Avatar
FinallyHappy
I have a couple of questions for ya, then I may be able to help more.
First, the guy you bought the tuner from had to return his car to stock and gave you the tuner AFTER he returned it to stock. Are you sure this happened?
Second, did you order a tune through someone and then have them email you a tune? You can't load a tune from the SCT if the tune file belonged to the previous owners car.
Third, If you did order your own tune file, then you should have sent the tuner your SCT serial number along with your strategy code or PCM number. Did this happen?
Answer those for me right quick!!
Old Mar 29, 2013 | 03:10 AM
moosestang's Avatar
moosestang
There are several different pcm codes, you need a tune written for your specific code.
Old Mar 29, 2013 | 09:18 AM
kevinmalec's Avatar
kevinmalec
If the custom tunes were not created specifically for your car, they will not work.
Call American Muscle or Brenspeed and order custom tunes. They will be able to create custom tunes specifically for your car and send to you via email to upload to the SCT handheld tuner. They will need to know your PCM code number, modifications and tire size. Good luck!
Old Mar 29, 2013 | 09:44 AM
crob1803's Avatar
crob1803
you guys helped so much. i was completely clueless. i have used a diablo tuner once without all of the hassle. he did return to stock BUT the standard tunes on the device wont work with my car. BUT ill get a custom tune asap, thanks A TON!
Old Mar 29, 2013 | 04:39 PM
Nuke's Avatar
Nuke
If the tunes in the tuner were from SCT, then they should have worked on your car but you wouldn't get the performance you were looking for. The fact they didn't work on your vehicle leads me to believe they were custom tunes (much better than the canned SCT tunes) for the previous owners car which will NOT work on your car unless your PCM has the same strategy code as the previous owner's car's PCM.
baddog671
Jul 26, 2016 01:20 PM
12bigredstang
Sep 24, 2015 05:46 PM
04stangman
Sep 17, 2015 01:45 PM
nboost
Sep 16, 2015 05:35 AM
ernesto-619
Sep 10, 2015 01:32 AM
