Crooked Wheels?
Old Apr 18, 2013 | 07:31 PM
GhostStrykre's Avatar
GhostStrykre
Default Crooked Wheels?
I installed my new wheels a couple weeks back and noticed that the left rear wheel pokes out a bit from the rear side panel. The right wheel does not, and is in fact sunken inside the rear side panel.
I called American Muscle and they said I need an adjustable pan hard bar to correct that. He also suggested checking the bushings to make sure they weren't worn. He said it isn't critical that I correct this crookedness but do you all feel differently? I had to break really hard today on the highway and my mustang started to wiggle/fish tail a bit. Is that a result of the crooked wheels? Btw, the front wheels look fine.
Old Apr 18, 2013 | 07:47 PM
CMcNam's Avatar
CMcNam
Is your car lowered? If it is the panhard bar will push the axle to one side, which is much more noticeable with wider rear tires. If that is the case, then AM's recommendation for an adjustable panhard bar is correct.
I haven't noticed any detrimental effects from my axle being off-center, but I do plan to correct it. My car fishtails anyways if I hammer it too hard.
Old Apr 18, 2013 | 10:11 PM
GhostStrykre
Hmm. It is not lowered. Just stock wheels and tires to aftermarket wheels and tires. I don't feel like this is a huge issue because I don't drive the car hard. Maybe a launch from a red light every now and then. So I feel like the adjustable PHB can wait. I'm hoping that's the case because the new wheels weren't cheap haha.
Old Apr 19, 2013 | 06:56 AM
05 Mustang's Avatar
05 Mustang
That's correct, an adjustable pan-hard bar will make it all better....I recommend BMR's PHR006 adjustable pan-hard bar with poly bushings on each end. Easy install, and even easier adjusting.
http://www.bmrsuspension.com/?page=p...&productid=172
Old Apr 19, 2013 | 07:09 AM
Bostonbuster's Avatar
Bostonbuster
Make sure you remove the brake rotor retaining clips also as they can cause wheel run out and vibration issues.
Old Apr 19, 2013 | 08:12 AM
Norm Peterson's Avatar
Norm Peterson
Wider than stock wheels, wider than stock tires, and wheels with a smaller positive offset than stock all tend to visually exaggerate any off-centeredness that was probably always there.
Theoretically, an off-center axle will cause a slight yawing of the car under heavy braking, but there can be other causes for the car not stopping straight as well.
It's not a high priority item, but I'd recommend fixing it eventually. Adjustable PHB is the least expensive way, but not the only way. Don't bother replacing the PHB brace.
Norm
Old Apr 19, 2013 | 08:53 AM
AMDanBailer's Avatar
AMDanBailer
Former Sponsor
This is correct. If your differential is off centered, the best way to fix this is an adjustable pan hard par! This will allow you to re center your axles at a very low cost.
Please let me know if you have any questions or need some assistance in the near future! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Old Apr 19, 2013 | 01:36 PM
GhostStrykre
thanks for the responses all... i hadn't thought about the fact that the wider wheels could have just shown what was already a flaw in the stock setup.. not surprising though. looks like i have to buy that Panhard bar. that'll push my CAI and Header plans back a bit though.
and btw, 05 Mustang, i absolutely LOVE that terminator in your signature. great stuff.
Old Apr 19, 2013 | 09:00 PM
05 Mustang's Avatar
05 Mustang
Thank you very much!
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
