View Poll Results: Which CAI PERFORMS the best.
Steeda
15
45.45%
Airaid
6.06%
JLT
16
48.48%
Voters: 33. You may not vote on this poll
CAI Debate.
Old May 3, 2013 | 05:31 AM
  #21
mapitts's Avatar
mapitts
Originally Posted by Nuke
Don't get hung up on the "COLD" in Cold Air Intake. For the effort to get true ambient air to the CAI, your gains will be barely noticeable, if at all, on a dyno (unless you're talking greater than a 50-75 degree differential and even then, minor impact).
+1. I am not really sure how the term Cold Air Intake got started, but a more accurate term would be a velocity stack. You do not gain any thing in the ambient air intake temperature department. What you do gain is the ability to pull in a larger volume of air and the flow is straightened up.
Old May 3, 2013 | 01:03 PM
  #22
ski's Avatar
ski
Originally Posted by 2005Redfire6
C&L is a good option but the thing with metal intakes they tend to run hotter/heat soak then a plastic intake.
Gotta respectfully disagree.
Even at idle rpm the velocity of the airflow thru the intake is so fast that it cannot absorb a sufficient amount of heat from the intake wall to cause its temperature to appreciably increase.
Also, the airflow has what is called a boundary layer, which is a thin layer of air next to the intake wall with an extremely slow velocity. This enables the boundary layer to become an insulating barrier between the intake wall and the air's main flow volume, which further reduces the amount of heat the air absorbs from the intake wall.
Old May 3, 2013 | 01:21 PM
  #23
ski's Avatar
ski
Originally Posted by 2011V6Nicole
I didnt know that, thanks for the info. Does it matter when your idling though? wouldn't it only matter when you are moving and using power?
The IAT increasing while the engine is idling does matter if you're either at a long stoplight or in line getting to the drag strip starting line. That's because the ECU starts pulling timing when the IAT exceeds approx. 100F to prevent pinging, and thus the engine will not be producing max power during the initial few seconds of acceleration.
Old May 3, 2013 | 10:27 PM
  #24
FivePointToTheOh's Avatar
FivePointToTheOh
Just Ordered the Steeda, We shall see how it all goes
Old May 3, 2013 | 10:54 PM
  #25
BleedinBlue's Avatar
BleedinBlue
It'll be fine.
Did you run a baseline pull to see what your numbers were stock?
Old May 4, 2013 | 06:44 AM
  #26
FivePointToTheOh
Originally Posted by BleedinBlue
It'll be fine.
Currently on Deployment, doing a run when I return later next month and then I'll install the exhaust.
Old May 6, 2013 | 09:23 AM
  #27
tj@steeda's Avatar
FivePoint,
You have made a great decision ... the quality of our product and the engineering/design that went into is incredible.
Please don't hesitate to contact me at tim@steeda.com if you have any questions or concerns.
Thank you once again for purchasing our product and serving our country.
Best Regards,
TJ
Old May 6, 2013 | 06:09 PM
  #28
mapitts's Avatar
mapitts
AMERICAN MADE
Old May 7, 2013 | 08:32 PM
  #29
Bmr4life's Avatar
Bmr4life
Carbon fiber looks the best.
Jb145700
Aug 21, 2022 06:37 AM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
junior04
Sep 28, 2015 10:53 AM
firecoyote
Sep 27, 2015 02:37 PM
