Help: High Speed Vibration
Pinion angle was ok. Here's what we found. The rear U-joint was tight, felt kind of binding in certain movements. Also, the front slide was not able to move at all. They found the shaft to be balanced good once those two issues were addressed. So we'll see, next time I get it up to higher speeds. But so far, it seems smoother even around 60ish. Could be all in my head, sometimes you think you notice things when you make a repair. LOL
Thanks once again guys for the input and the suggestions. Everything always helps!!
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
