Aftermarket subs on a base system?
I know this topic always comes up, but I've been poking around different forums and still can't really find out what I need to know...
I'm a huge music nut, it's probably my biggest passion after my car, and when I built my car I opted to go with the base sound system thinking I could just buy an adapter for the dash and throw in a single din head unit and be done... but after knowing that you need a whole new dash kit and being limited to a double din head unit, it sucks to say but I'm not in the position to spend $1,000+ on all that BEFORE speakers subs enclosures and an amps.
So my question is: Is there any safe way to run say... a 12" sub to my stock head unit without frying it, or is my only choice really to buy some aftermarket 6x9 speakers and try to get as much bass as i can out of them. I've done some audio stuff to my past car but I'm by no means an expert.
I'd really appreciate some input/help from people who've done it before because I know I'm not the only one who has this problem lol.
"Shoulda got a shaker" >.<
Adding an amp is not that big of a deal. btw, I have started with the shaker 500 and it was pretty disappointing.
The signals to the rear speakers on the shaker 500 is not filtered, they have all of the frequencies. This makes it pretty easy to get an amp with speaker inputs and drive it with the rear speaker signals. I think your rear speakers are the same. The mid-high range door speakers are pretty easy to replace, they are driven by the head which has about 12W RMS. If you get high power speakers the head will not be able to drive them very well.
The shaker 500 has 8" subs in the doors, the factory speakers are crap, imho.
There are a lot of info in the Audio section. https://mustangforums.com/forum/audi...ker-500-a.html
I'm doing the same thing. I just installed my wiring kit. Just gotta get the amp in there and hooked up with my 12. You just need a power, ground, turn on, and rca cables. Once those are all installed, youll need a hi-lo adapter to adjust the frequency and power to the amp to level it out. Then you should be good. Theres a thread on the wiring.. Its still missing info but it got me halfway through my process. Im currently researching where to splice the hi-lo adapter. good luck!
https://mustangforums.com/forum/2005...-a-2013-a.html
http://www.moddedmustangs.com/forums...se-system.html
FWIW, I just put in a double din Kenwood for $200. It's nothing fancy, but gets the job done and sounds great.
If you do tap into the rear speakers, I would put a switch to the amp. That way you can turn it off. If you buy the right kind of amp, you can do it without RCA cables. I don't know what that amp is called,just know I had one.
Low-level input has to use RCAs and will need a convertor with a factory head unit. Again tap into the rear speakers, connect the wires from the rear speakers to the line out convertor, then plug the RCAs into the amp.
This site has some basic info to help understand a few things, but its a great place to purchase from
http://www.crutchfield.com/S-lVtR0bq.../oem_amps.html
I posted on another forum as well... people are saying to splice your adapter to the rear speaker wires. i'll post a link in case you want to look at it, i've gotten some good replies.
for 05-09 at least, the wire colors are
Left Rear Positive(+) GY/LB
Left Rear Negative(-) TN/YE
Right Rear Positive(+) OG/RD
Right Rear Negative(-) BN/YE
Can someone help me out on electronics here? I'm having trouble. Heres my thread, scroll down for the latest progress:
https://mustangforums.com/forum/audi...rter-help.html
