How big a spare can I fit?
Old Nov 18, 2013 | 12:30 AM
WJBertrand's Avatar
WJBertrand
Default How big a spare can I fit?
Just took delivery of my 2013 GT with Brembo brakes. This model comes with a "mobility package" or some such instead of a spare tire. I haven't tried it yet, but the spare tire well looks almost large enough to fit one of the 19" wheel with 255/40 tires in there. I thinking about buying an extra wheel and tire but I'm not sure if I can fit a full sized one in there. I'm guessing anything smaller than a 19" would have to go on the rear only due to the Brembos? Thanks!
Old Nov 18, 2013 | 08:12 AM
edwin108's Avatar
edwin108
You can fit a full size spare in there, but it will stick up past the well and lift up the liner/carpet.
Old Nov 18, 2013 | 08:21 AM
Andy13186's Avatar
Andy13186
a full size rim and tire will add about 60 lbs of weight, but alteast its in the rear and relatively low.
The floor liner in the trunk is a cardboard type of material, if you put anything heavy in the trunk with no spare it will probably bend it, mine has a hole poked in it from the jack support rod thing.
Personally i would probably just put in a normal spare size if anything.
and measure the diameter of the wheel well to be sure a full size will fit, i think stock brembo tires are 27 inch tall
Old Nov 18, 2013 | 08:30 AM
PNYXPRESS's Avatar
PNYXPRESS
Pull one of your wheels off and check its fitment.
Old Nov 18, 2013 | 02:34 PM
WJBertrand's Avatar
WJBertrand
Thanks for the replies. Maybe I'll do some shopping for a used spare, any good sources? I've purchased a cheap scissor jack and lug wrench to put in there as even without a spare, there should be some way to remove a wheel on the road somewhere. I also added a tire plug kit. I've had decent luck with these in the past and I might be able to avoid using the sealant Ford supplies that way. The manual says the TPMS sensor must be replaced after you use the sealer.
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
mdg
Oct 1, 2015 07:04 AM
