Lowering my stang, will rear end be safe?
#21
A 1.5 drop will not put your PA out of whack with a stock driveshaft at all. You don't have to get an adjustable UCA. If you do get one the install is basic on a 06. I have the same car. You don't have to drop the gas tank not even close. LCA will eliminate all wheel hop and are a great cheap mod. I reused all the bolts. An adjustable panhard is a must with your drop and installs really easy. I have all J&M parts and have no noises, squeaks etc with them.
#23
For the 1.4" drop, you don't HAVE to install anything, other than the springs themselves.
You SHOULD upgrade the panhard bar so you can center the rear end.
You SHOULD upgrade the LCAs at ANY height because they improve grip in a straight line and in the corners.
You SHOULD replace the UCA for the same reasons.
You DO have to drop the tank if you replace the flimsy stock UCA mount. (recommended)
I used all UPR Products suspension on my 2006 GT and it made for a great handling daily driver.
www.UPRproducts.com
www.UPRproducts.com
musnicki
09-23-2015 07:11 AM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
