HELP: Plastic Part under Chassis
Old Feb 18, 2014 | 10:26 AM
rivertown's Avatar
rivertown
Default HELP: Plastic Part under Chassis
Hello Guys,
I see a plastic part under the chassis of my 2014 Mustang 3.7, I attached pics. This part is on the passenger side. Could anyone tell me if this is normal and if your 2014 Mustang has the same part? My concern is I warped this part when I back off onto an ice chunk on the ground.
Thanks a lot!
Attached Thumbnails HELP: Plastic Part under Chassis-pic1.jpg   HELP: Plastic Part under Chassis-pic2.jpg   HELP: Plastic Part under Chassis-pic3.jpg
Old Feb 18, 2014 | 12:58 PM
SPARTAN VI's Avatar
SPARTAN VI
I have a 2014 GT, same piece but mine is flush against the chassis.
Old Feb 18, 2014 | 01:18 PM
rivertown's Avatar
rivertown
Thanks, SPARTAN.
I think mine should also be flush with chassis, but I warped it when backing off into a pile of snow. Do you know the name of this part and the cost to fix or replace it?
Old Feb 18, 2014 | 01:47 PM
dlazrael's Avatar
dlazrael
looks like some sort of deflector shield to protect whatever that line is...... i have no idea how to even begin to define it
Old Feb 18, 2014 | 01:52 PM
rivertown's Avatar
rivertown
dlazrael,
Thanks.
I found a pic online in which that part is labeled as "fuel tank stone guard".
Old Feb 18, 2014 | 05:56 PM
2005Redfire6's Avatar
2005Redfire6
They are normal, wind deflectors/"stone guard" like you mentioned.
Old Feb 18, 2014 | 08:49 PM
steel pony's Avatar
steel pony
Which help protect the fuel line and/or fuel return line that sit right behind it
Here's a link:
https://parts.autonationfordwhitebea...iagram=JC10681
They are parts #6 & #7
Old Feb 18, 2014 | 10:50 PM
rivertown's Avatar
rivertown
Thank you guys, I think I already know the name and use of this part. But based on SPARTAN VI's picture, mine is obviously warped. I talked to the dealer today, they will charge 60 for the part and 50 for labor to replace it.
Old Feb 19, 2014 | 12:23 AM
Roy_R's Avatar
Roy_R
Should take you all of 5sec to replace it...
Old Feb 19, 2014 | 12:31 AM
SPARTAN VI's Avatar
SPARTAN VI
Werd. It's 2 bolts, and there's probably enough clearance under your car so wouldn't even need a jack/ramps.
mtgldr
Feb 3, 2024 09:00 PM
Vrooom
Feb 21, 2016 05:25 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
tmdm
Sep 17, 2015 08:51 PM
Sep 17, 2015 07:57 PM
