shift light install question
Old Oct 12, 2005 | 05:51 PM
V8 Aggie's Avatar
V8 Aggie
Default shift light install question
lol I know this looks easy as hell to most of you but i have a question.. here is install procedures http://www.raptorperformance.com/For...stang_2005.htm . What do i need to tap into for a switched 12 volts power supply? thanks
Old Oct 12, 2005 | 07:54 PM
Twister086's Avatar
Twister086
Default RE: shift light install question
ill have to look at my fuse box tonight. there should be a whole section of fuses at are only hot with battery voltage (12volts) when the key is in the run position. and even better if theres a empty fuse spot already. ill get back to you after i look at my car tonight
Old Oct 12, 2005 | 08:39 PM
jtscuba02's Avatar
jtscuba02
i bought the autometer tach drive,rpm switch and shift light. i havent put it in yet but from what i can tell i will do it the same way i did the electric waterpump. run the 12v wire inside the car and use a blade connector and plug it in to an empty fuse slot. if i was you i wouldnt cut any wires for anything. use the splice connector that you dont have to cut any wires. if you ever have an electrical problem you can take the car back to the dealer without cut wires and get it fixed under warranty. also if you make a mistake all you do is remove the connector. this is just my opinion, but i wouldnt cut any wires. if you dont mind, how much did you pay for all your stuff? for the autometer stuff it was like 200 bucks. good luck, jt
Old Oct 12, 2005 | 08:46 PM
V8 Aggie's Avatar
V8 Aggie
it came out to be $117. ya i use the splice connectors! but what is it so that I can plug the wire into a fuse slot. right now it is just a bare wire...
Old Oct 12, 2005 | 08:56 PM
jtscuba02's Avatar
jtscuba02
use the blade type connector, its flat like a screwdriver. you may have to trim it up a little to get it to fit, but you should a few open fuse slots inside the car. look at the owners manual and it will tell you.
Old Oct 13, 2005 | 01:30 AM
281GT's Avatar
281GT
If you are tapping into any wire I would use solder and heat shrink. It makes a clean looking, realiable connection that will not come apart. Ever. Those stupid plastic connectors are intended for temporary use only and they are NOT reliable. The metal parts of them are usually made from aluminum and aluminum corrodes if used for electrical serice. There's a reason aluminum was outlawed in home electrical service! It will also corrode if used under the hood as these connecters are not usually weather sealed.
Solder and heat shrink! I cannot stress this enough. SOLDER and HEAT SHRINK!!!
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
kdryan
Aug 21, 2015 04:01 PM
jjwinel78
Aug 17, 2015 03:34 PM
Mnuckolls
Aug 9, 2015 08:54 AM
