Transmission problems
Old Feb 24, 2014 | 06:54 AM
audioAl's Avatar
audioAl
I also do the seafoam and techron treatments. An oil catch can will help also.
Old Feb 24, 2014 | 11:38 AM
jz78817's Avatar
jz78817
Originally Posted by HardyHartnagel
Yes, the engine revs up but I don't move. I then let off the gas and it jolts and it then accelerates the next time I touch the gas.
sounds like you're losing line pressure inside the trans. maybe a problem with the pump or valve body.
Old Feb 24, 2014 | 07:56 PM
Nuke's Avatar
Nuke
With that info, it certainly does sound tranny related.
Old Feb 24, 2014 | 08:27 PM
RetiredSFC 97's Avatar
RetiredSFC 97
Take it to a shop and ask them to diagnose it. Unless you're a tranny mechanic you can't fix it if it is a tranny issue. Personally I have never seen a bad tranny act like that, usually they slip all the time, or they don't. The possibility on it being tranny related could be an issue with the torque converter. Sometimes they can act like that.
Old Feb 25, 2014 | 12:34 AM
808muscle's Avatar
808muscle
your fluid could be low and thats not good for the auto trans. There is not dipstick so you gotta follow the owners manual on how to check it or take it to a shop. Dont wait to do this, low fluid can ruin a transmission.
Old Feb 25, 2014 | 12:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Something to consider with these "sealed" transmissions. Ford recommend a complete fluid flush ever 30K mile. I doubt most people do that including the previous owner of your car OP.
From personal experience, the tranny flush makes a huge difference with these cars. I started to get some harsh shifting a few thousand miles ago (55k ish and also before the first flush around 28K) I had the fluid replaced around 30K and had it replaced a couple of weeks ago. Both times the tranny worked fine for another couple years and almost 30 K miles.
BTW high heat is an enemy of tranny fluid. Above 175F it starts to lose its lube properties exponentially so your weird shifting pattern is about right (60K vs my 30K experience with much higher operating temps being that I'm in AZ).
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
