WIX Oil Filter vs a regular?
I failed to mention that now that I'm driving the Stang well less than 10k miles/year, I'm changing the synthetic oil on a time basis; 1 year; and because of the reduction in mileage over what I USED to drive her annually, I'm now using the Motorcraft filter. My SUV, on the other hand, is on 8k-10k miles (depending on how much of those miles were spent towing which can often be easily 10-20% or more) gets M1 filters until my stock runs out, and then it's the Amsoil Ea.
Running the oil 10k+ miles isn't a big deal but running an oil filter that long is. The filter needs to be changed out on a more frequent basis as it is where particles are being stored when caught
As long as you change the filter on a regular basis you can get away with a cheaper filter.
With that said I change my oil every 10k miles and the filter every 5k miles
Ea Filters designated with product code Ea15K are recommended for 15,000 miles/one year, whichever comes first, in normal or severe service.
Ea Filters designated with product code EaO are recommended for 25,000 miles/one year, whichever comes first, in normal service or 15,000 miles/one year, whichever comes first, in severe service.
I was using the EaO filters and I would have had no problem running well beyond 10k miles on both the oil AND filter when I was using Amsoil in the Stang. A 10k mile frequency was a conservative choice, IMO.
They may be able to go that long but how clogged with gunk are they going to get from the stuff they filter out prohibiting oil flow. And if it doesn't affect flow then what kind of stuff are they not filtering out?
I'm not a expert on the subject but common sense says that stopping debris will stop flow over time.
