Sponsored by:
Sponsored by:
2006 4.0L
Old 09-16-2014, 12:58 PM
kwh1811
kwh1811's Avatar
Default 2006 4.0L
Can someone PLEASE tell me how to make sure I have the timing correct before I reassemble the motor after replacing the head gaskets? I cant find any timing marks on this engine.
kwh1811 is offline
Old 09-16-2014, 11:57 PM
Lethaldosage423
Lethaldosage423's Avatar
Rule of thumb. ALWAYS index everything before you take it apart!
These motors require special tools to hold the cam gear in place so it doesn't move.
if you made any marks on the gears (cam gears and crank gears) then put the motor back to them.
if not. id recommend setting the crank at TDC and find out where the cams are supposed to face?
if not, call a ford service manager and see if he will be kind enough to share
Lethaldosage423 is offline
PullTab
10-30-2015 08:46 AM
kevsgt
10-09-2015 10:12 PM
Seanam
10-04-2015 10:15 AM
BeatnikFink
10-01-2015 08:00 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: 2006 4.0L
