bouncy suspension help
hello,
I have 2013 conv V6. 19 in avant grande wheels, SVE Progressive Rate Lowering Springs but the car is little to bouncy for my taste. How can I improve my suspension??
the koni str.t shocks and stuts work good for getting rid of the bouncyness....I lowered my car and kept the stock shocks and struts and it was really bouncy. switching to the shocks made a huge difference and solved the problem.
Strange 10-way adjustable shocks and struts are very reasonably priced, and they work well.
http://www.uprproducts.com/strange-m...-shock-05.html
http://www.uprproducts.com/strange-m...-strut-11.html
Did you change the rear bump stops or cut the top off the stock set? When you lower if you leave the stock bump stops it will be a rough/bouncy ride. I had the same thing on my 2006 when I put the Roush rear springs in, and when I cut the top off the bump stop it was improved 100%
Bump stop issues usually show up as a ride that's too harsh - feels like the car hits things too hard, which you feel as a stinging impact kind of thing right when you hit a bump rather than as body motion afterward.
I'm betting that this installation was with new springs only.
Norm
Matt's 95 Stang
Oct 5, 2015 07:16 AM
