GEAR RATIO's
GEAR RATIO's
With all the recent questions on RPM vs speed vs Final Drive Ratio, i thought I would put together a little
chart. This is for the TR-3650 Manual, and 235-55/r17 tires.
If i get a chance I'll calculate & post info on the T-5 and Automatics
All speeds are theoretical as wheel slippage and aerodynamic drag will reduce these speeds
the faster you attempt to go.
Code:
Speed at 2000 RPM Final Drive 3.23 3.31 3.55 3.73 3.9 4.1 4.3 4.56 1st 14.4 14 13.1 12.4 11.9 11.3 10.8 10.2 2cd 24.3 23.7 22.1 21 20.1 19.1 18.2 17.2 3rd 36.8 35.9 33.5 31.9 30.5 29 27.6 26.1 4th 48.6 47.4 44.2 42.1 40.2 38.3 36.5 34.4 5th 71.4 69.7 65 61.8 59.1 56.3 53.6 50.6
Code:
Speed at 6000 RPM Final Drive 3.23 3.31 3.55 3.73 3.9 4.1 4.3 4.56 1st 43.1 42.1 39.2 37.3 35.7 34 32.4 30.5 2cd 72.8 71.1 66.3 63.1 60.3 57.4 54.7 51.6 3rd 110.4 107.7 100.4 95.6 91.4 86.9 82.9 78.2 4th 145.7 142.2 132.6 126.2 120.7 114.8 109.4 103.2 5th 214.2 209.1 194.9 185.5 177.4 168.8 160.9 151.8
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
