Low noise from front end when turning slow in parking lots
#21
What is the purpose of removing the fuse? That would lead to a pump that isn't pumping, with the engine running?
And later, with the fuse back in, when I turn the key to "on" (electricity/lights turn on), the pump would be pumping again but the engine would not be running?
Sorry for all the questions, just having trouble following.
After you have the fuse put back in, you will probably have air in your fuel lines or not enough pressure to start the car. By putting the fuse back in and turning the key to 'On' but not starting it, you are priming the fuel system. Just like you stated. When you've starved the engine of fuel, it can take a couple of priming cycles to get the fuel system properly primed.
P.S. There's more than one way to disable an engine and allow it to crank without starting. I generally prefer to remove fuel from the scenario because if you turn the engine over too much and there is fuel, you can flood the motor which can make it harder to start when you are ready to.
#22
In other words, couldn't I drain the PS fluid while simultaneously filling it with fresh fluid all while the car is running normally?
#24
Welp, I could not get the metal clamp off the return line. The tabs are on the underside, so I can't squeeze them together. Tried prying, no luck. Tried unscrewing the reservoir so that I could manipulate it to get a better angle. No luck. And in the process I tilted the reservoir sideways such that I probably introduced air into the line.
So I siphoned some fluid out and refilled. I'll do that 3-4 times this week and hope that helps. When I took the siphon tube out, I noticed some crud on the tip.
#25
Okay, I see. But why don't I want the engine to run? Is it because the power steering pump would be operating after faster RPM, while if the engine is just cranking it would pump at a slower rate?
