emergency brake cable wearing thru?
Has anyone noticed their emergency brake cables wearing thru where they pass through the rear control arms? Both sides have worn thru the rubber, but I don't think there's been any damage to the steel cable within yet. This is on my '08 V6 model. Just wondering if there might be a TSB out there before I head to the dealership. If this isn't a design coming flaw, then I don't what is.
thanks
Jeff
thanks
Jeff
From here, it looks like it's only worn through the sacrificial sleeve, and has only just started to wear into the cable's outer shell.
It's a cheap but effective way of ensuring that the cable survives the warranty period. And frankly, that's all that Ford cares about.
2 - lightly sand the hole the cable goes through. One of your arms looks like it has a ton of rust and dirt build up which will act like sand paper if the cable is always rubbing against it. Securing the cable better will reduce the sandpapering effect but unless you clean the openings up a bit, it will still be sand papered.
