Rumbling While Accelerating
Old Jan 27, 2018 | 06:44 PM
Josh Hoffman's Avatar
Josh Hoffman
Default Rumbling While Accelerating
Hey guys. I drive a 2007 V6 Mustang. I did a quick check and didn't see anything specific for my issue. Last night I did an oil change and replaced the spark plugs and wires. everything was fine, I drive to work today and as im driving i notice a little rumbling when i hit about 50mph. Feels like I'm driving off-road when it happens. I get further down the road and and notice that the rumbling only happens when trying to accelerate. gentle pressure on the gas and very slow acceleration was ok. Then i get to work and it wont start. I hear clicking, some of which sounds to come from the under the hood fuse box but there is no turn over like the battery is dead but that is not the problem. I'm pretty sure the starter needs to be replaced but if you guys have any ideas as to what the rumbling is that'd be much appreciated
Old Jan 28, 2018 | 11:27 AM
Buck Sergeant's Avatar
Buck Sergeant
Josh, when reading your post for the first time, when you mentioned "Rumbling at about 50 mph," I immediately thought "driveshaft." And that might be a separate problem. But, the driveshaft wouldn't cause the engine not to start. If the battery is no longer "fully charged" could you have accidently disconnected a wire in your charging system while changing the plugs and wires??? Driving to work may have taken long enough to discharge the battery. Check all your wiring for a loose or disconnected wire.
Old Jan 28, 2018 | 12:25 PM
Dino Dino Bambino's Avatar
Dino Dino Bambino
The center bearing of the stock two-piece driveshaft is probably failing.
Check the contacts between the battery cables and posts for looseness or corrosion.
Old Jan 28, 2018 | 05:44 PM
JimC's Avatar
Super Moderator
When you replaced the wires you might have mixed up the pattern. It is very easy to do with the 4.0 coil. It is in numerical order on one side, but not the other. The car will start and run with them mixed up because of the waste spark system, but you will get issues as you described.
So look at the coil and trace your wires to make sure you didn't mix things up.
Hawkschwier
Jul 23, 2010 11:54 PM
xmonielx
4 Cylinder NA and Turbo
18
Apr 24, 2007 06:23 PM
four-sixer
Aug 4, 2006 05:07 PM
tightdogal
Nov 8, 2005 10:16 PM
01yamahar6
Oct 28, 2005 08:43 AM
