Mustang has been shaking for months PLEASE HELP SOS
IF the sway bar has play, it's the bushings. Still, I had replaced the bushings on my
Charger twice, and before each time, never had front end shaking, just the clunk on
bumps. Bad end links will cause play, but not in the same way bad bushings do.
Bad bushings, you have up and down lift, side to side shimmy on the whole bar itself.
Bad end links, you have play in the torsion movements.
Like I said, fill the front tires to 39lbs, then run it to where it shook. That will
eliminate irregularities in the tire itself.
ba1dwin
05-29-2011 01:50 PM
