need help with coolant change/flush
Old Jul 16, 2018 | 07:32 PM
winkawak's Avatar
winkawak
Default need help with coolant change/flush
Its almost 6 years, coolant change/flush maintenance is comin up. What are the proper procedure of changing coolant on a 2013 mustang?This will be my first time doing a coolant change and i cant seem to find a how to regarding my year mustang.
Old Jul 17, 2018 | 04:44 AM
08'MustangDude's Avatar
08'MustangDude
Banned
You can buy a "T" fitting that goes in the upper rad hose, so you can flush
it with a hose, IF you want to flush it. Else, drain the coolant through the
rad pepcock, and refill with the same stuff. If you flush it, you can
use almost any coolant that's compatible.
If there is no rad pepcock, then remove the lower rad hose... Hmm, come to
think of it, would be much faster...
Old Jul 17, 2018 | 12:33 PM
winkawak's Avatar
winkawak
so no need for a coolant flush?
Old Jul 17, 2018 | 12:34 PM
winkawak's Avatar
winkawak
so no need for a coolant flush? i saw some videos not mustang but all recommended flushing done with distilled water. What about bleeding afterward?
Old Jul 17, 2018 | 05:36 PM
08'MustangDude
Banned
Personally, I have never, EVER flushed my coolant systems, and with that never EVER had
a problem.
However, when you refill the system, you use distilled water and concentrated coolant.
Any time I have had to replace a radiator, I used vacuum to put -35hg into the rad at the fill
neck, then release the coolant, and it will fill every single nook and cranny in the coolant
system. Very neat, I might add... Even without this, I have never had to bleed a system,
guess I am just lucky. I just squeeze and release the lower and upper hoses when filling up,
and keep at it till I get no more air bubbles from the system. Then I run the engine hot, then
repeat and add coolant when needed, keeping an eye on the temp gauge. SO far, I have
never had a issue... Though, there are bleeding steps, just never had to do it.
juancvilla
Apr 2, 2010 06:48 PM
krazymofo22
Feb 21, 2010 09:12 PM
AChinkinaMustang
Dec 16, 2008 05:01 PM
misfit6794
Dec 13, 2008 02:43 PM
Olivarez
SVT Forums
May 13, 2008 08:18 PM
