SVT Forums
rad. flush and refill HELP
Old May 11, 2008 | 10:33 PM
Olivarez's Avatar
Olivarez
Default rad. flush and refill HELP
Can some one explain to me how to flush and changethe coolant. I have a 96 cobra, my light came on for low coolant. So just wanted to flush it and change rather then just refilling it because idont know when the last time it was change just got it 2 months ago. Thanks for your help
Old May 12, 2008 | 12:00 AM
Does Not Exist's Avatar
Does Not Exist
Default RE: rad. flush and refill HELP
How to flush a radiator.
Hope that helps. [8D][8D]
Old May 12, 2008 | 08:05 AM
pitmitch910's Avatar
pitmitch910
an easy way to drain the system is undo the thermostat, its at the bottom of the system, and when you refill just make sure it doesnt hav an air lock in the system.
Old May 12, 2008 | 02:02 PM
RuffCat's Avatar
RuffCat
ORIGINAL: boostin95cobra
That just came up as google for me! Anyways, Buy a haynes manual and it will tell you. I would unhook the lower hose that goes into the therm housing. I would really change the thermostat while you have all of the coolant out. They are only a couple of bucks and the last thing you want is a faulty thermostat because you'll have to drain out ALL of the coolant again! When you have everything together (double check all of your clamps are on) You need to fill the resevoir until it won't take anymore. Then you need to unscrew the block/off screw on the crossover tune. A 1/4" ratchet fts perfect. You will probably break an extension so just use the ratchet itself as the shaft on the unit itslef is pretty tough. It's gonna be very hard and all the sudden you will think you broke the socket...haha That's what all I have done sounded like. It just means it's loosened or you actually broke the socket! You need to pour coolant slowly into there as that fills the other side of the motor! This is a MUST MUST MUST or your coolant will not circulate and you'll run your waterpump dry! After coolant flows over the top, screw the plug back on and keep your resevior cap off. Start the car and get it up to temp. Just keep an eye on the coolant level. It shouldn't get lower, if anything it will overflow out of the resevior. No big deal. After the car gets warm, shut it down and let it cool. After it's on the lower side of the temp range squeeze the left rad. hose gently to get any trapped air out of there. Do that a few times. Start your car agian and get warm. Then shut off, top off if necessary and put your coolant reseviour cap back on and your all set. ( drive over cardboard before you begin as the cardboard will soak up most of the coolant that gets spilled! Makes for an easy clean-up.
Old May 12, 2008 | 08:06 PM
Does Not Exist
ORIGINAL: RuffCat
Hmmmmmm....weird.[sm=icon_rofl.gif]
Old May 12, 2008 | 08:13 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
While letting it burb with the cross over tube plug removed is one way to do it, mine was so seized on there I gave up on that way. Easiest way to fill it and burp it is to borrow somebodies vacuum filler..
I have one of these.. http://buy1.snapon.com/catalog/item....mp;dir=catalog
Works like a charm, on any vehicle, no more air bubbles. And you can vacuum and fill the system in about 3 minutes
Old May 13, 2008 | 08:18 PM
Olivarez's Avatar
Olivarez
thanks for all your help it wasnt to bad ....
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
Sep 10, 2015 07:23 PM
