Brake light issue
Old Aug 8, 2018 | 04:16 PM
CadenOquinn's Avatar
CadenOquinn
Default Brake light issue
Ok so my running lights work(when I turn on my headlights they turn on,they are the same bulb as the brake lights) but whenever I press my brakes they don’t get brighter . When I use my blinker they do and my hazards so the bulbs are fine but I can’t figure out why they just stoped working .is there a fuse or a ground I can check (2007 gt)I
Old Aug 8, 2018 | 08:57 PM
2007CalSpec's Avatar
2007CalSpec
Check fuse #15 in the SJB (smart junction box). That's in the passenger side kick panel. Also check fuse #63 in the BEC (bussed electrical center). That's in the engine compartment passenger side. Also check your stop lamp switch behind the brake pedal. Good luck!
Wiring diagram:
http://iihs.net/fsm/?d=40&f=Turn%20S...rd%20Lamps.pdf
BEC:
http://iihs.net/fsm/?d=40&f=Fuse%20a...nformation.pdf
Stop lamp switch:
http://iihs.net/fsm/?d=391&f=Stoplamp%20Switch.pdf
CadenOquinn
Aug 9, 2018 06:08 PM
CadenOquinn
Aug 8, 2018 09:20 AM
kaswam
Aug 22, 2010 02:18 PM
kami
Nov 14, 2006 05:54 PM
vegeton
Jun 13, 2006 11:01 PM
