Left headlight doesnt work
Old May 4, 2019 | 05:05 PM
Crakajtw's Avatar
Crakajtw
Default Left headlight doesnt work
Hey all, i know this has been posted before buy my 2006 GTs left headlight isnt working on low beam. Ive replaced the bulb and soldered in a new connector. Still no low beam but i do have high beams. The rightside works flawlesly. Now i probe the connector and i have voltage when its mot plugged in but lose it when i plug it in. I unplugged the sjb and the right headlight comes on but the left still doesnt. Wjich leads me to believe there is a wiring issue. Has anyone every experienced this?
Old May 5, 2019 | 02:23 AM
08'MustangDude's Avatar
08'MustangDude
Banned
Did you know that each low beam has it's own fuse? 7 & 8 are the 10A fuses
for the lo-beams, 7 being left. Hi-beams are single 15A fuse.
Old May 5, 2019 | 06:38 PM
Crakajtw's Avatar
Crakajtw
No i didnt. I thought they werent fused. Which fusebox am i looking at?
Old May 5, 2019 | 09:04 PM
Crakajtw's Avatar
Crakajtw
So i looked in both the underhood and inside fuse panels and either one 7 and eight arent both 10 amp fuses. In the owners manual those arent listed as headlight fuses. So, not sure were to go from here.
Old May 7, 2019 | 01:59 PM
08'MustangDude
Banned
Sorry, a diagram I saw on-line said that, but this does not:
http://knigaproavto.ru/shemy/en/ford...x-diagram.html
The low beam on the 05 up Mustangs do not have a fuse. They are controlled by the "smart junction box" ( SJB )
Check fuse F2.4 (10a) and F2.10 (10a) in the SJB.
Right side HD-connector low-beam pin 3 color=DB/LG Fuse=F2.4
Left side HD-connector low-beam pin 3 color=WH/LG Fuse=F2.10
I read that too...
Old May 8, 2019 | 05:30 AM
Crakajtw's Avatar
Crakajtw
So which fuses are f2.4 and f2.10? Also, when i disconnect the sjb both headlights should turn on low beam (i read this on a another thread), but the left doesnt turn on and the right does.
stallion11030
Oct 11, 2008 05:23 PM
LesteR723
Jul 6, 2007 10:22 AM
FBCBEER
Jan 5, 2007 07:20 PM
mustang96gt
Feb 6, 2006 11:54 PM
Shifty
May 17, 2005 10:06 PM
