HELP?! Headlight problem?!?!
Old Jan 4, 2007 | 05:24 PM
FBCBEER's Avatar
FBCBEER
Default HELP?! Headlight problem?!?!
Both of my headlights wont turn on. My turn signals work and so do my fogs, but not the headlights. I know its probably a fuse, but I dont have the manual to check which one it would be.
Does anyone know which is the low beam fuse number? or what else could be the problem?
Old Jan 4, 2007 | 05:46 PM
Baron von Munchausen's Avatar
Default RE: HELP?! Headlight problem?!?!
10a Mini fuse numbers 4 and 10 in the interior under-dash fuse panel (right and left hand low-beam headlights respectively), or more likely the 30a maxi fuse number 2 in the engine bay fuse box.
Old Jan 4, 2007 | 06:34 PM
FBCBEER's Avatar
FBCBEER
well, I just looked under the hood and no fuse was blown. I looked at the lights and the are dual bulbs and one filament was broken on each bulb.
What could make both low beam filaments break?
On a side note, does anyone have silverstar ultras?
Old Jan 4, 2007 | 10:32 PM
98ponycar's Avatar
98ponycar
Say, they didn'tfailat the same time. You have been driving around with an inoperative headlamp and didn't know it untill the second one failed.
Old Jan 4, 2007 | 11:15 PM
x9Mustang9x's Avatar
x9Mustang9x
thats kinda strange...
silverstars are whiteee!!!
Old Jan 5, 2007 | 02:33 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
No there was someone a while back that actually had both of their low beams go at the same time. It's not common but it does happen.
Ryan
Old Jan 5, 2007 | 07:20 PM
mcccop_04's Avatar
mcccop_04
i have ultras now in my new headlights (not the projectors) and i really do love them...
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
