2006 windows leak during storms
Old Aug 31, 2020 | 07:59 AM
Burnhaven's Avatar
Burnhaven
Default 2006 windows leak during storms
I have the 2006 Mustang two-door with V6. There is no garage currently and I've noticed that although the window weatherstripping seems fine and the windows do seem to retract all the way up when the doors shut, if it's a windy/rainy storm I'll get wet carpets even if the car hasn't been driven ( not coming up through floorboard or down behind firewall ). I'm wondering if there is some aftermarket sealing trick or if I'm just going to have to put a weatherproof cover over the car?
Old Aug 31, 2020 | 03:07 PM
bl817's Avatar
bl817
your cowl drains are plugged and the cowl channel fills up with water and then spills in thru the cabin filter housing, thus resulting in the wet carpet and weird electrical issues as the SJB in the passenger side kick panel gets wet and the connections corrode over time. there are 2 cowl drains, the pass side is down between the battery and back of engine, you might be able to see it but for sure feel it if you get your had down there. its an oblong 3 or so inch rubber funnel type drain, just pull it out and clean it and reinstall. the drivers side is in the same relative area on opposite side. very common issue on the S197 cars and even had several TSB available to read. good luck
Old Aug 31, 2020 | 04:03 PM
mapitts's Avatar
mapitts
Look beside your battery against the firewall. Under the cowl you will see a "rubber thing". Like bl187 said. You may need to see it with a flash light. When you find it, just gently pull it out and clean it. Very easy fix.
Old Aug 31, 2020 | 04:51 PM
Burnhaven's Avatar
Burnhaven
I pulled those rubber drain plugs out of the firewall a long time ago when I was noticing the carpet at the passenger Foot area getting wet ....This most recent occurrence Was mainly on the floor behind the passenger seat nothing in the front seat floor area at all That's why I'm thinking that when the wind blows hard it's somehow getting around the windows... I just don't think this car was designed to sit outside of a garage in the winter If nothing else I'll put some kind of tarp over it
Old Sep 1, 2020 | 05:29 PM
bl817's Avatar
bl817
if thats the case, its your seals above the upper door trim. search my threads and go back a bit. i used truck bed camper seal to fix both sides for about 10$ and less than a casual days work.
Old Sep 1, 2020 | 07:12 PM
Burnhaven's Avatar
Burnhaven
Thanks, I'll search for that
Rogue972
Jan 26, 2011 10:30 PM
wolfpack_freak
Mach 1 Section
Oct 31, 2009 04:15 PM
ssrc76
Jul 17, 2007 10:26 PM
The stang II
Nov 9, 2006 08:11 PM
cwalsh7
Jun 6, 2006 12:15 PM
