Rear end vibration???
Old Mar 15, 2023 | 08:31 PM
dg8882's Avatar
dg8882
Default Rear end vibration???
So my rear axle was developing a bad vibration over 100mph only when coasting, completely goes away when accelerating at all and not present at all below 100mph.
I rebuilt my rear end, and found a heavily pitted carrier bearing race. I also put in 4.10 gears while everything was apart. Testing it out, there's still a vibration over 100. It's much less bad, and is tolerable now but still occurs exactly at 100+. Given it still happens at the same speed with different gears, I think that rules out driveshaft/trans/pinion? That leaves the carrier, axle bearings, and wheels. I don't think it's the wheels since it didn't change with a rotation.
Any ideas what would cause vibration coasting over 100?
Old Mar 15, 2023 | 09:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Dump the carrier bearing configuration with the two piece driveshaft\. Go with a one piece and get a drive shaft loop. The stock driveshaft cannot be serviced. You have to buy a whole new one. May as well make it a lighter aluminum one.
Old Mar 16, 2023 | 07:43 AM
dg8882's Avatar
dg8882
should of mentioned, I have been running the aluminum shaft for about 2 years.
Old Mar 16, 2023 | 11:18 AM
Derf00's Avatar
Derf00
Gentleman's Relish
Try clocking/indexing your drive shaft. Remove the 4 bolts on the transmission side, rotate it 90 degrees and retighten. See in what position the vibration is the most tolerable or goes away completely. Most of the time when it comes to drivetrain vibrations, it's harmonics that cause the vibrations. If you can get the harmonics to cancel each other out, you reduce/eliminate vibrations.
Old Mar 18, 2023 | 11:45 AM
_CJ's Avatar
_CJ
Pinion angle?
Old Mar 20, 2023 | 04:34 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Originally Posted by _CJ
Pinion angle?
That's a thought. If it gets worse over time, that could be the suspension relaxing. If it's not lowered and the problem didn't just start but rather, was gradual over time, it could be the pinion angle.
Charlies197
Mar 3, 2020 03:05 PM
JComo
May 21, 2018 07:34 PM
fisher2985
28
May 10, 2010 10:01 PM
cheetha94607
Jan 3, 2008 09:13 AM
90GT347
Jun 23, 2004 08:10 PM
