O2 Sensor Codes?
Old Jun 14, 2023 | 02:15 PM
joey1500's Avatar
joey1500
Default O2 Sensor Codes?
Hello All,
I'm hoping someone could point me in the right direction with an issue with my 2005 GT 4.6. The best I can describe the issue is an engine "stutter" that happens in the low RPM range and only under load. No issues with idle, or RPMs above 2,800 or so. It only happens when the engine is lugged down a bit and it's definitely getting worse over time.
I've long suspected I had a wire shorting somewhere because it seems to happen more often when I am turning. I can also make it worse by loading up the electrical system (lights, power windows, radio). I've been checking for loose grounds and cleaning them with wire brushes but getting nowhere. Yesterday I finally bought a cheap code reader and was surprised to find the only codes were O2 sensor related. I've looked up the codes and they are as follows:
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
Now, I'm no mechanic by any stretch of the imagination but I find it hard to believe that 4 different sensors are all bad? I was thinking maybe there is a common link between all of the sensors?
My code reader lets me clear the codes. When I did that the problem went away entirely for an hour or so and then came back along with the check engine light. Does that make it more likely to be a computer issue?
Lastly, the car has also had a problem with the AC compressor intermittently turning off from time to time. I don't know if those could be related but I figured I'd mention it just in case.
Thanks in advance.
Old Nov 29, 2023 | 10:37 PM
Edqe's Avatar
Edqe
You looked into the ignition switch? I read somewhere on other ford models that the ignition switch is a common cause for all your O2 sensors issues.
Old Dec 4, 2023 | 06:43 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Never heard of this. I'd like to see some of these threads or forum postings where a bad ignition switch has caused issues with the O2 sensors on a Mustang or any Ford vehicle (or any make for that matter).
Old Dec 4, 2023 | 06:51 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Originally Posted by joey1500
Hello All,
Thanks in advance.
Check your SJB, it's the fuse box in the passenger side kick panel. On 05 to 07, it was known to get water leaks from rain. The water would cause corrosion and lead to all sorts of weird problems. Here's a link to the TSB on it and the remedies. This latest TSB include all 05-09 mustangs and only mentions the leak. It does not mention about the corrosion it can cause.
https://latemodel.cachefly.net/downl...sb08-26-07.pdf
fred lfde
Mar 28, 2020 02:39 PM
sharkred7
Aug 4, 2019 07:16 AM
RED guy
Jul 1, 2008 12:19 PM
JH23
Mar 30, 2007 12:16 PM
04blackterminator
SVT Forums
Feb 24, 2007 11:38 PM
